rushmore
Extreme Android User
I have noticed the one big issue for me with the GS3 is "ghost" signal, and it is Ghost Hunter signal worthy of fakeness.
The area I live only has 3G and the signal with my previous devices (Inc, D2, D3 and Razr) have all had great 3G signal and results. The GS3 also shows great signal, but the results are weak in many areas. Tested with Opensignal and other apps. All show great signal as well, but download speed is slow and battery life is a lot less when using much.
This issue is not varied, since happens in specific areas without fail. The odd thing in other areas I get weaker signal, but better results (than ghost signal) and places that the strong signal matches the speed. This seems very strange to have areas where signal and speed correlate, but other specific areas that show strong signal, but get slow speed.
It is to the point where I do not trust what the GS3 reports for 3G signal, since the results do not match as much as previous devices. This is an issue I absolutely did not have with previous VZW devices and have two to compare with now (Droid 2 & 3).
The ghost signal areas also result in a hotter running device. This does not seem to happen in 4G areas and not all 3G areas. This scenario and GPS are the two hottest temp running events that I have tested (still not as hot as the Razr got).
Added: This is really starting to bug me. Phone call range is just as good as previous devices, but the ghost signal for some 3G areas is strange. Same issue with the white one and older kernel, but was thinking it was network issues, due to short time of having the device. Droid 2 and 3 shows same strong signal, but works fine with 3g in the same areas and no funky battery drain.
