Wallpaper battery drainage
  • Thread starter Thread starter Member2047631
  • Start date Start date
M
Member2047631
Guest
Is it true that wallpaper that isn't just an out right color drain your battery faster?
Yes, solid black would use the least amount of battery, while a live wallpaper would use the most
Do you have an idea of the percentage rate lower if it's a normal picture?
Never tested anything, but I mostly use a photo as my wallpaper and my phone holds a charge for the day into the evening
It depends on what sort of display your phone has:
* AMOLED use least power when displaying a black image because they turn the LEDs off to make dark pixels, and conversely use most power when displaying white. So if you have an OLED display then you can save some power by using a black wallpaper or dark theme.
* LCD have a backlight and then pass light through different coloured filters to make up the image. So actually it makes little to no difference what your wallpaper is with an LCD - the backlight is on anyway, and that's the main drain.
How much time does your phone spend with the display on and showing the wallpaper though? Because that's the only time it will make any difference.
Live wallpapers are different: they are actually apps which are having to use the cpu to perform calculations in order to animate the background, so they will use more power than any static wallpaper.
I have a Lenovo tab 4 10 and I don't think it even supports live wallpapers because I tried one and it didn't work, and usually I don't spend that much time on the home screen, but I did find a cool one:
Well wouldn't the battery drain faster because of it having to display a picture rather than how bright it is?
