** ZTE Warp Sync N9515 **
** Boost Mobile KK 4.4.2 **
This is a normal ROM update for the KK 4.4.2 firmware. The main differences I noticed was:
~ the ability to now correctly read my 128GB micro sdcard
~ overall smoother
~ Stagefright patches
* Partition Updater zip *
It is recommended to install the B07 partition updater as sometimes ROMs won't function properly without them - https://www.androidfilehost.com/?fid=24545070682210355
* Stock Unmodified (NO ROOT) - https://www.androidfilehost.com/?fid=24545065934258393
* Stock Deodexed/Debloated (ROOTED) - https://www.androidfilehost.com/?fid=24545065934258197
+ Went ahead and made the kernel insecure to access files with PC while in other modes plus added init.d support
The files removed from DeBloating... WARNING, these ARE NOT FLASHABLE!!
Unpack the zip to access the files - https://www.androidfilehost.com/?fid=24545070682210330
Credits:
- @SuperR ! For giving us the Partition Updater.zip, tools, time, & education to make this happen.
- @arcaina For uploading the files to work with.
-- If ya like the work, just hit thanks in the OP!!
~ overall smoother
Credits:
u mean B05 maybe ?
