Help Water Damage Testing and LCD Replacement
gordonfink
I have two issues that are connected. I have a water damaged S3. I cleaned up the board, which didn't really look too bad.
Now, everything works but the LCD (at least I think so). Kies sees it, and the touchscreen works. With two side by side, I can press the same spot on the damaged one, and the phone responds, so it seems the touchscreen works.
Is it possible (I know it's difficult) to replace the LCD only? If I'm going to have to throw away the screen/lcd assembly and buy a new one, I might as well try it first.
Thanks
