Help Water damage to screen?
LehFoxeh
So I just recently got a screen protector that is applied with the wet solution. (I forget which brand, doesnt really matter). I absolutely loved the protector, it was easy to install and had NO air or particulate bubbles under it. My case started to peel up the protector on one side after a few weeks though, so I went ahead and peeled it up some and applied some more of the application liquid to stick it back down better.
However, when I turned it back on after, I've noticed that there has been some weird discolorations in my screen now. It still seems to work ok, but it seems like there's got to be some of the water (or whatever that liquid is) underneath the screen and it's messing with the display.
I had it on today because I needed to use it, but I have it off now. I'll stick it in some rice when I get home, but it doesnt seem like the function of the phone is diminished at all, just that the image on the screen is a bit weird. Is that fixable?
