Help Water Damaged Galaxy Ace
My Galaxy Ace fell into some water, I quickly retreived it and stripped it and dried it out with a hair dryer and tissues, put it back together and it seemed OK as it fired up and went through the start up procedure, however once its was up and running it went through the start up procedure again and again and it continues to do that until eventually it turns itself completely off after about 5 min, this is happening when the phone is running off the battery, when I plug the charger in it stays on, I've tried 2 other different batteries but the problem remains, can anyone help?
Hello philsteriom and welcome to Android Forums. :)
The water might've caused some corrosion causing it to do that. You might need to get a replacement maybe.
