Wave lock with Material design[Lock/Unlock screen by wave hand]
kimcy929
Wave lock is an application use Proximity Sensor to lock screen and unlock screen for android device of you. You can use it instead POWER BUTTON. Application design by Material Style(Material Design) of Android Lollipop
With wave lock you can:
Lock screen any where
- Unlock screen
- Set time delay to lock screen
- Launcher app with boot mode
- Disable lock when screen at landscape modeIt is an application and every easy use
To use application use wave your hand through Proximity Sensor near Light Sensor.
EXIT APPLICATION BEFORE USE IT
Thanks you so much.
Link download CH Playsotre https://play.google.com/store/apps/details?id=com.kimcy92.wavelock
Video demo
More image
OtBCEc1soksKq2D7fPCpMv7g2RNAvrL1RZzsNY4EGwHGXm6mWdBLOubdJIt4qhBLL4E=h900
4_Gdk0wpeCw6hJ7snvX0NPADuI4-Oe8ltn855zEBnarbi3qA6QC_uYM9Iw2jAvFhEA=h900
