Waze for Android Auto
Connect your phone via USB to your car. Launch Android Auto to make sure you are connected to the car. Mine automatically connects. On the Car Display screen the Android auto home screen should show several icons accross the bottom. The map icon should show a pull down arrow which lets you select Maps or Waze as the program to display.That should do it.
Same here. Pretty easy on my Civic.
