We need a speed dialer
scrannel
Member
I know, you can make short cuts, but they are a real pain (and unsafe) to use while driving. It would be great to long press on any number in the dialer and dial a selected number.
By the way, I'm sure you've notcied if you select a number on the dialer, then press # a contact number on your SIM card appears. Not sure what the hell they were thinking of with that one...
Try the app Star Contacts - I use it instead of the default Contact app. Then just contact the author and suggest this feature. It's a great idea.
I tried Star Contacts, uninstalled.
Took up too much previous screen space.
AnyCut works PERFECT for what scrennel is wanting to do. I have a speed dialer for my wife, and one for work. And a few more instant SMS links.
