Help Weak wifi signal
I just bought one S Advance few days ago.i noticed that my wi-fi signal is significantly lower than my girlfriend's HTC Rhyme. Also when i keep the phone on my desk, in the same room with the rooter (3 meters away from it) my wifi signal is full Instead when i pick the device in my hand the signal drops 1 or even 2 lines of signal and it keeps oscilating. Not mentioning that in public places i sometimes can't connect to a wifi because i don't have enough signal but the HTC does.
I nstalled several wifi monitors like wifi analyzer or wifi signal info and the last one shows how my signal decreseases when i pick the device in my hand (aprox 15-20%).The internet still works fine in the same room with thee router but if i go few meters from the room it drops significantly and charging internet pages becomes poor or null.And in public places is kind of funny.If i keep the device on the table the signal is 2-3 lines but when i put it under the table or just turn the back on the router the signal just drops 1 line and the internet is not working anymore
I want to know if it`s my device problem only or if someone else is experiencing the same. I saw a lot of posts about weak wifi signal on SGS II. Does the S advance has the same problem ?
Should i return the device to the provider for replacement or it's just normal?
