Weather Channel battery drain.
I've had my S7 for about a month and really like it. The battery life has been very good for me lasting at least 12 hrs. under normal use. Today the battery has drained twice as fast and when I check the battery usage it shows weather channel at the top using 37%. I've had the weather channel app. since day one and have it set not to update or notify. I check it maybe 2 or 3 times a day. I have never had this happen before. Any ideas? Thanks Bob
Maybe it's just a one time glitch. Try going to your Settings >> Application manager, find your weather app, and then tap on the 'Force stop' button and then the 'Clear cache' button. Now be sure to restart that app and wait to see if this has made any difference.
