web browser keeps going to a website
  • Start date Start date
A
Android Question
Guest
Hi. My web browser keeps going to www.goolgle.com even though I have deleted my history, reset my browser, and I've even tried using another web browser (Chrome). I also did a factory reset. Why does my phone keep doing this? I have a Galaxy S3. My homepage is set to Google.
Because you set your homepage to Google....
Welcome to Android Forums!
You said in your post that the browser was going to 'www.goolgle.com.' Note the extra l. If that's a typo, and it should be google, then yes, your browser will always bring up the homepage when it first starts up.
If it wasn't a typo, then we may need more info to be able to help you. Check the homepage setting of your browser and make sure you didn't accidently put Goolgle instead of Google.
I hope this helps! If not, there are two avenues: You can re-submit your question with additional info the same way you submitted this one, or you can join the forums for a better back and forth exchange of info.
If you choose to register, here's the link:
Register today!<----Link
