Webview Example
Hello
I am a newbie.
I am using Android Studio (Android Studio Dolphin | 2021.3.1 Patch 1).
Is there a simple 'webview' example which I can refer to?
Please advise.
Thanks.
Here is a simple example of how to use a WebView in an Android app:
Code:
import android.os.Bundle;
import android.webkit.WebView;
import android.webkit.WebViewClient;
import androidx.appcompat.app.AppCompatActivity;
public class MainActivity extends AppCompatActivity {
    private WebView webView;
    @Override
        setContentView(R.layout.activity_main);
        webView = findViewById(R.id.webview);
        webView.setWebViewClient(new WebViewClient());
        webView.loadUrl("https://www.example.com");
    @Override
    public void onBackPressed() {
        if (webView.canGoBack()) {
            webView.goBack();
        } else {
            super.onBackPressed();
You will need to add the INTERNET permission to your app's manifest file in order to use a WebView. To do this, add the following line to your AndroidManifest.xml file:
Code:
<uses-permission android:name="android.permission.INTERNET"/>
You will also need to add the WebView element to your layout file. For example, you could add the following to your activity_main.xml layout file:
Code:
<WebView
    android:id="@+id/webview"
    android:layout_height="match_parent"/>
