Apps Webview HTTPS Bypass Theory ( Needs a little help )
Ryanteck
Member
Hi
i have a webview application that i am developing a solution to an https error i have.
I know that WebView dont support HTTPS but the normal android browser dose work so i started to work on the idea of it opening the https page in the browser then after people could go back to the application.
so far i found the following code that detects the website link and only allows this url to work.
Code:
lass MyWebViewClient extends WebViewClient {
	public boolean shouldOverrideUrlLoading(WebView view, String url) {
		// Check if page is trying to connect to an https page
				if (Uri.parse(url).getHost().equals("http://example.com")){
					return false;
				Intent intent = new Intent(Intent.ACTION_VIEW, Uri.parse(url));
				startActivity(intent);
				return true;
	private void startActivity(Intent intent) {
		// TODO Auto-generated method stub
So why not reverse the detection to
Code:
				if (Uri.parse(url).getHost().contains("https://")){
				// run code if detected
// This is where i need help with a popup code
					return false;
//run code if not detected
				return true;
so if someone knows how to make that url to then open up in a new website window then it would work perfect so then it detects anything conntaining https and opens it up in a new window.
Thanks ryan
When I'm using WebView, am getting blank page. I've set uses-permission to INTERNET in manifest.xml but even then am getting a blank page. Any help is highly appreciated.
WebView wv = new WebView(this);
setContentView(wv);
wv.getSettings().setJavaScriptEnabled(true);​
wv.loadUrl(url);
is the code I've written.
