Weird icon stuck
AlexT95
I have that weird icon stuck and i dont know what it is or how to get rid of it so please help
[/IMG]
from the link you sent me i can see that the icon is similar to speakers on... ive disabled s voice and i cleared cache ...still the icon persists
I just checked my phone, and I have S voice set up and it starts when I turn on my phone, so I can use my headsets and place calls. I had my headset on and placed a call with S voice and that icon never showed up on my phone, so I think it's not for S voice.
My search tells me it means your speaker phone is in use...
And do you know how could i fix this issue? I've tried a lot of things and none work.
If you turn your phone off and back on, and the icon reappears, my next guess is a reset of the phone, but I am only taking a guess. These things are kinda like a computer and sometimes just a reboot fixes things...
After any update I do a Wipe of Cache Partition. Next step would be a master reset but that puts your phone back to factory fresh... Good luck, keep us posted.
yes i have tried all the methods pointed by you guys but nothing seems to work... i think i will need a factory reset.... i will try to investigate before i take a factory reset keeping you updated
I once has a full wallpaper from a game that was being advertised.
never knew how it got onto the phone.
had to do a full complete reset and reregister the phone.
so this is how it looks like when i activate speakers on during a call
no ..i have not installed call related apps.also when i put phone on plane mode that icon disappears ..but it gets back on when im in normal mode
there isn't ...the notification bar is clear...also i've noticed that the icon randomly disappears and reappears after awhile
no wifi calling enabled
i don't have VoLTE option..or at least i can't access it but i switched from autoconnect 4g/3g/2g to 3g/2g and the disappeard.. and if i select again the 4g/3g/2g it appears ...what is the problem...i had 4g before and that icon wasn't there
Hmm I thought Wi-Fi calling could be it, I'm personally stumped. Good luck finding out the cause!
