Root Weird problem... no Home app
OK, so, this all started with me rooting my Cliq. So far so good. I then deblurred it with a script, and that seemed to work fine too. After that I noticed that something (not sure what?) kept trying to sync on my phone constantly and was burning through the battery very quickly... I tried uininstalling several apps that I thought were the problem, but no joy. So I decided to do a factory reset on my phone. Well, the phone booted up, but I don't appear to have a home application... ??
Here is what I think happened:
-Deblurring my phone removed Motorola's stock home app, leaving me with Launcher Pro (which is what I normally used)
-Wiping my phone removed Launcher Pro, leaving me with... nothing.
When I wipe the phone and go through the Motoblur setup, I get to a black screen with a notification panel at the top. I can pull the panel down, and I can also hold down the upper-right button and get some options (turn on/off wifi, turn on/off GPS, power on/off, etc.). I thought maybe that I could just install another ROM, or at least re-install Launcher Pro... but since I have no home application I can't figur out how to get to the Settings to turn USB debugging on, so adb will not see my phone. I have RSDLite also, but not entirely sure how to use that...
Anyone have any suggestions?
So did your phone ok now??? if not I know how to recover it from that position.I have had the same problem,and I recovered it.
Maybe that could help me too... how do I install another "home" program... I rooted the phone and it had launcherpro on it (and it expired and locked my phone and couldn't update itself either)...
Rus
Hey guys, sorry to the delayed response... yeah, I managed to fix it after a few days. Texting worked on the phone, so I sent a text to myself with the URL to launcherpro... downloaded that and installed it and I was up and running.
Fonehacker, what was your fix?
