Hi Folks,
Some more advice would be appreciated.
I have my HTC One X running nicely on Leedroid but wanted to install the Faux kernel as I'm reading good things about that.
I downloaded Faux from here:
[Kernel] (004 beta 5) Hybrid (DVFS-UV Control/CPU_G/LP/AVP/EMC) [Jul-06] - xda-developers
I did recovery etc.
I then did:
fastboot flash boot boot.img
fastboot erase cache
fastboot reboot
But the phone gives me Bootloop. I tried using CWM to erase Dalvik Cache in case the fastboot erase cache wasn't working. But still got bootloop.
In the end I gave up and reflashed the previous boot.image file (using same fastboot flash boot boot.img process as above).
And this has resolved my Bootloop.
But any ideas what I did wrong when trying to flash the Faux kernel in that might have caused my bootloop?
Is the faux kernel compatible with UK/International HOX's?
Or does a kernel flash require extracting the ROM again from the SD zip file so the ROM is built upon the current kernel?
Cheers,
Alan
I did recovery etc.
I then did:
fastboot reboot
Cheers,
Alan
