Is there anything that will switch wifi on & off automatically to known networks?
So for example when I get home it will connect to my home network automatically & switch off when I leave the house?
The following app will do exactly what you asked!
Y5 - Battery Saver - Android app on AppBrain
Despite the unusual name, it will automatically switch to wifi when in range of "known" networks (any wifi network you've successfully connected to), and switches wifi off when no longer in range. I use this daily - when I leave for work wifi automatically shuts off, then turns back on and connects to my home network when I get back home. I also use it for auto-connecting to wifi networks in stores I frequent (Bob Evans, Barnes & Noble, etc.). Best of all it's free!
You can download it from either Appbrain using the link above or find it in the market - just search on "Y5" and it should come right up.
Just what I am looking for.
Top stuff!
EDIT: I use Extended Controls to toggle wifi on/off so I guess the switch won't be accurate as to whether it's on or off?
