What apps will dial a number for me?
OM2
I can't find a massive selection...
MySMS does it - I have paid yearly subscription - BUT... it's sooo sooo buggy. Calls only get made 70% of the time. :(
Mightytext does it... but it's so buggy and stops working every x days - I give up on this one. :(
Airdroid - OK... this is the most reliable... but it's tooo big and bloated - I don't want anything else it offers!
Is there any other apps I can look at?
ALL I want to do is send a number from my PC and have the phone dial.
I'll have my bluetooth headset on - becomes so convenient.
When you have to make 20+ calls, having the ability to call from PC and not having to look at screen and type numbers, is invaluable!
When I search for 'call number from pc' - I get loads of apps that give free calls - I don't want free VOIP calls or something - I just want to call from my mobile!
Thanks!
... and what device?
I use a Droid Turbo 2 with touch less control. I just say "OK Turbo" "Call Mary Smith" and it makes a call to her.
... Thom
If you set up Google Now ("OK Google") you can say,
"OK Google... Call John Doe mobile/home/work." or...
"OK Google... Call 123-456-7890"
Isn't that easier than sending a number from your PC to your phone and then dialing it?
