roman hernandez
I am hoping someone will be able to answer this question for me, as metro has never been able to give me an accurate answer. I realize the call detail is fro 2010. I see on my call detail where voicemail was called and checked. But, in mid Oct 2010, I started seenig calls made to various different 714 area code numbers, None of these numbers were a true persons phone, it rang more like a fax machine or payphone, Each call is followed by an incoming call and for around the same duration in length. The phone was an older flip phone and I have copied and pasted an example of the call logs below, as well as shared the link of the entire call log
https://docs.google.com/spreadsheets/d/1xWPJXXMQvipqYBRr4AaDmxgj2KRBFn359yhtQ4ex8LE/edit?usp=sharing
Oct-15-201018:31 0:00:24 7144990682 Outgoing
Oct-15-201018:31 0:00:22 9512512102 Incoming
Oct-15-201022:13 0:00:19 7144990322 Outgoing
Oct-15-201022:13 0:00:18 9512512102 Incoming
Oct-16-201004:46 0:00:02 7144990137 Outgoing
Oct-16-201004:46 0:00:02 9512512102 Incoming
Oct-16-201013:43 0:01:23 9512512102 Outgoing=This is a regular call made to voicemail
Oct-16-201013:43 0:01:21 9512512102 Incoming
Oct-16-201015:02 0:00:21 7144990298 Outgoing-But here it looks like a call made to vm with the incoming call the same time and duration
Oct-16-201015:02 0:00:20 9512512102 Incoming
Oct-16-201015:32 0:00:28 9512512102 Incoming
Oct-16-201015:32 0:00:26 9512512102 Incoming
