What do I do with my Note4?
foxwiz
I have a Note4. It has already been replaced by Verizon because of the reboot loop. When I got the replacement phone, it did the same thing. A continuous reboot loop. Looked through all the suggestions on the forum, cleared cache, rebooted, reset the phone. Nothing works.
So my question is, is the phone even worth selling? How much do you think I can get for it in it's critical condition?
has the vZW store replaced the SIM card?
my note 4 would not work on 4g, only 3g or lower.
they replaced the SIM and it fired right up on 4g.....
if you want to move it, give me a PM and we can talk about it.
I think I fried mine a while back, waiting on a new battery for it... if that don't work, I will need another Note 4 to try and get going. I never buy new...
Gotta go through the usuals:
1) figure out what you're doing (or what you've done) when it happens
2) test without the sd card (if you have one) and sim card
3) factory reset with "automatic restore" off, then setup as new (don't restore from a prior backup), and don't sign in or restore anything until you've had a chance to test
4) reflash the software (a samsung experience shop in a best buy or use verizon's software repair assistant)
I did test without the SD and SIM card and I did do a factory reset and tried all the options in safe mode. Nothing works. Since I was out of contract, I decided to purchase a new phone and now I just want to get rid of this one. If I can get some money for it, I will be a happy camper.
