Hi all,
I'm about to buy a phablet(Cube-U51GTW) , it is actualy a 7" tablet wich i would use as a cellphone and also as a navigation device in my car.
After watching a lot of youtube videos i got lost
I'm looking for a steady mount that will hold the device and prevent it from shaking while driving.
I live in a very hot country so it's important that the mount will have some kind of protection over the phabet. I'm sure that direct sun whould not do good to the device.
To prevent the phablet fron blocking the front view i prefer mounts that will stick to the dashboard and go down towards the radio.
Even the cd slot mount is a better solution than the windshield ones but both cd slot and the windshield mounts are too risky and the phablet would probably shake.
Which mount do you prefer for your 7" talets\phablets ?
Thanks
Thanks
