What is the correct way how to do a reset?
Milo Willamson
Extreme Android User
For a softbrick moto z2 force, I have tried multipule, volume up and power, volume down and power, volume both with power, power hold thirty second rule with charging, and mostly was without charging,b ecasue my cord will not reach nearby my comp so i can test it out though, anything I am missing though folks?
Usually holding the power button down will give you a menu. Did you see a menu doing that Milo Williamson? If you did, what where your options?
nope, nothing. I have been trying out every method known to man, by force of googling these past going on nine days, every moment i got free from that slavery occupation.
Are you attempting a soft reset to clear memory, or opened apps or a forced recovery reset/factory data reset
I think what you are wanting to do is a forced recovery reset/ factory data reset If so, shut your phone off.
Next hold in the volume down button, then press the power button to confirm the action. Usually the pressing of these buttons must be done simultaneously, but according to several sites I have followed up on, concerning your device,is it's not necessary.
Keep holding the buttons in until the bios information pops up on the screen.
Let go quickly of both buttons. You should be in factory data reset mode/wipe cache/partitions/logs
Now use the volume up or down to scroll to to your menu option. Use the power button as your selection button.
Sometimes, it just takes timing and a few tries to get there. I think that's pretty much any phone.
I hope this works for you.
Next hold in the volume down button, then press the power button to confirm the action. Usually the pressing of these buttons must be done simultaneously, but according to several sites I have followed up on, concerning your device,is it's not necessary. Keep holding the buttons in until the bios information pops up on the screen. Let go quickly of both buttons. You should be in factory data reset mode/wipe cache/partitions/logs
For how long ? I tried it two minutes, i tried it ten second way, just give me the straight up answer of how long. That is all I wanted to know, do not sound so vague.
Luckily there is a sale going on in verizon.com's web site, the sales guy might do to that for a drop off price too :) Same phone too. (mental note do not download anything from a indie programer from google play..)
nothing at all, been looking throughout the XDA for options, I camed close to coding an entire notepad ++, still needed the bootlander to move over and a few other things from the rootjunky's order. But i do not have time right now, so i will hit you up soon.
If you want to do a recovery reset via recovery as @Steve Perez inquired, and the button method doesn't work, you could try using ADB if you are familiar with it.
Then again, if you are going to Verizon to exchange it, and the sales guy will do it, ADB might not be worth the hassle if you are not familiar with ADB ;)
Been reading a lot of ADB funny thing though, I want to try my hands on it first :) Thanks man, i meant to say this morning, i woke up around 3:30 a.m., read about Android Data Base (think that is what it meant spell out) about it though, just wondering what is the excat time I should just wait until I tough and use the buttons again. Tried this morning, and held them for tweleve minutes, when i was posting the last post i did.
Next hold in the volume down button, then press the power button to confirm the action. Usually the pressing of these buttons must be done simultaneously, but according to several sites I have followed up on, concerning your device,is it's not necessary. Let go quickly of both buttons. You should be in factory data reset mode/wipe cache/partitions/logs
But what excat time I was munching at?
I must have misunderstood you. Didn't know you were talking about the time..
It's just that some phones can pretty go into the factory data reset menu quicker than others. It may take 30 seconds or if you have one like mine, it takes about 2 to 3 minutes.
That is why I didn't specify any time on how long you should hold the buttons. I simply said to hold the buttons in until the menu pops up and immediately release the buttons. I worked all night so I must not have caught on, as tired as I was.
I hope you were able to get it done. Have a blessed day.
Nooooooooooooooooooooooooooooooooooooooooooopppppppppppppppeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee..............
Must kill humans, must exterminate, summon the supreme Dalek!!!!
Almost got it rebooted off gizrom, but I was half asleep and must of download the wrong rom though :(
ADB is actuallyan acronym for Android Debug Bridge.
If a site told you it was the Android Data Base, I'd suggest not using that site anymore for any information related to Android and android devices.
