Kurniawan
Hai i just learn about android developement, why i can't add despendencies support.
example if i add this despendencies :
implementation 'com.android.support:cardview-v7:28.0.0'
Always out notification:
Version 28 (intended for Android Pie and below) is the last version of the legacy support library, so we recommend that you migrate to AndroidX libraries when using Android Q and moving forward. The IDE can help with this: Refactor > Migrate to AndroidX... less... (Ctrl+F1)
So i must migrate to androidx, and then despendencies change to :
implementation 'androidx.cardview:cardview:1.0.0'
Because if i learn on tutorial, always use android not androidx, but i can't use android despendencies.
Thanks
Thanks
