DarkKirby
One has a SP at the end of the Model number and the other doesn't newegg sells the one with an SP in it for $10-$15 more then the one without an SP in the model number, but other then that the Details on both 32GB Micro SD Cards are identical. They are both labeled as speed class 4 as well. I've looked online but can't find an answer.
Thanks for any help you can provide.
