Daniel Fernandes
I get this type mismatch error that I don't really understand, I've been stuck on it for quite a long while and I haven't really figured it out. The error looks like this:
Type inference failed. Expected type mismatch:
required: Array<Uri>?
found: Array<Uri?>
What exactly does the question mark mean and what's the difference in their positions?
I get this error at onActivityResult. The activity has a webview. When the user clicks an "Upload Image" button on the website, the app shows a file chooser, and gets the result back, then the image is sent to webview. Here's its code snippet:
found: Array<Uri?>
Code:
override fun onActivityResult(requestCode: Int, resultCode: Int, data: Intent?) {
super.onActivityResult(requestCode, resultCode, data)
if(resultCode == file_req_code){
if (resultCode == Activity.RESULT_CANCELED) {
file_path?.onReceiveValue(null) //file_path is the filePathCallback
return
if(resultCode == Activity.RESULT_OK){
if (file_path == null){
return
var image: Array<Uri>? = null
image = arrayOf(data.data) //I get the error here! "arrayOf(data.data)" is underlined in red.
file_path?.onReceiveValue(image)
