whats your battery drain after 30min of continuous usage?
tracerit
With the stock battery I use up 30% battery an hour (15% over 30 min) when browsing the internet continuously.
with the official sprint 2600mah extended battery I only use up 12% an hour!
With the stock battery ill only get 3.3 hours of use and with the extended battery 8 hours of use. I'm wondering if I have a bad stock battery if the difference is so high. that or the 2600mah battery is really like a 3500mah battery.
Mods, don't merge this thread into the others. No one ever replies to those huge threads anymore.
Anyway, I dont know about all that extended battery stuff, but why do all that when you can root and add a custom rom to your phone? I only loose about 3% in 30 minutes usage. My battery goes well into the second day without charge and my evo is not huge and clunky. Just tryin to help....
Before I installed a custom kernal I was getting about 12-14 hrs with light usage. But now after this custom kernal it should be seeing a bit more. However if you do this it will void your warranty.
