Help Whatsapp annoying problem..
Sonsho
Hello everyone, I've formatted my phone, and I have to pass through whatsapp verification once again, but the problem is I am using a Morocco Sim card, and now I'm in Turkey so I don't have any credit available, is there any alternate way of doing this ? Thanks for your help !
AFAIK you need to verify your phone number which will require you to have credit
Although I've not tried it I believe it's possible to use a landline to receive a verification code. There are instructions in the Help/FAQ section in Whatsapp settings.
Have a look at this.
Hope this helps.
IF you need whatsapp urgently then you can try verifiying your whatsapp with online sms bypassing verifications .. you can use it to hide your identity also..
step 1 : install whatsapp on your phone.
Step 2 : go to receivefreesms.com or you can try other free sms bypass sites
step 3: choose any number (which country you want) from website (dont close website yet) and put it in sms verification of whatsapp.
Step 4 : you will receive sms online just fill that code in verification box..
