yeah just downloading it. i agree about the google maps. i told my friend after using s3, blackberry feels like stoneage. lmao. any other apps or wallpapers etc. which u can suggest to download?
- SwiftKey 3, takes your whole typing experience to the next level. don't look at what you're typing, just type really fast without looking and watch how SwiftKey's auto correct is so smart that it gets 95% of what you type correctly
- Instagram, for nice after effects of photos you snap
- Evernote, have you notes always available and synchornized/backed up with the evernote server. you can access the same notes on your pc by installing evernote on your pc! Want to edit or add a new note, you can do so from your PC and it is magically on your Galaxy as well thanks to the syncrhonization
- Google Reader, free RSS reader
- CamScanner, the best scanner app that scans images into a PDF that is crisp and clear. I bought the full version license for 4 USD I think
- LightFlow, the best LED notifications app. You can have diff. color lights for diff. evens. For example, if I get a whatsapp messenger message, the LED lights green, if I get a Faceboopk notification, the LED lights blue, if I get an email, the LED lights white...that's how I set it up. It is very easy to set up
- MyBackup Pro, backs aup all your apps so you can reinstall them easier should you have a total device failure or want to revert to an older version of an app because the new update was buggy
- TuneIn Radio, the best internet radio I've used. You can listen to local radio stations all over the world by selecting it from the locations, then you will see a list of those local channels
- Flashlight +, for when you need light in the dark,very strong light I love it
- Shazam, the best song recognition app, let it listen to any song and it will quickly identify it
