A
Android Question
Guest
Hi There!
So I just recently updated my Moto G to Lollipop and decided to try the USB On-The-Go storage. I bought a 64GB Sandisk Ultra Dual USB Drive so I could put some music on it and listen to it on my phone. I connected the drive to my phone and the 'option' to tap the "Mount USB On-The-Go storage was available, but after tapping it, nothing happened. I'm wondering if this is an issue from the new update or if there is any way to fix this? Ive tried third party apps with no luck. Thank you in advance!!!
