Sounds like you're using the WiFi connection for your DSL to access the internet instead of your phones mobile data.
To turn on mobile data the process varies by phone, but should be similar to:
Open the phones menu.
Tap Settings.
Tap Data Usage or Wireless and Networks, or similar.
Look for any Cellular or Mobile Data options and enable it.
