androidtvfan
How long is a piece of string?
My Note is still V5.0.![]()
from what I have been reading, you and I are in the Lucky Group.
I don't want MM, as it takes away too much and gives nothing in return.
Perhaps not ground-breaking,but,I bet the battery life will be greatly improved.Hi, I can't see much difference up to now, it's certainly no great forward! Phil
This is from the Note5,but,perhaps the feature you're looking for is still there,if what I understand what you're looking for,FF to the :50 mark of this how-to:Can anyone with the 6.01 update confirm that image clip has gone, or is it located somewhere else rather than from the S Pen menu?
Had mine updated yesterday on the Vodafone network. Everything ok so far except I have to put in my password instead of my fingerprint when I switch off and then on again. Did not have to do that before...
