Where in the system settings is night mode?
JohnJSal
Android Expert
I'm using Nova Launcher Prime and I just noticed that night mode is on, but it says it's turned on based on my system settings. I can't seem to turn it off from the Nova settings.
So where can I find this in my settings?
Thanks!
Night Mode was pulled from the Android 6.0 Marshmallow official release but is supposed to return with 7.0 Nougat. Meanwhile just tap on where it says Follow system and change to either Auto for it to change with Sunrise and Sunset or Custom to have it change on your own defined schedule. You'll see the most change your App drawer and the settings menus which will get darker. Change back to floow system to get the white background back.
UPDATE:
If you can turn on the System UI Tuner settings there will be controls there. HTC didn't include it but try this on your S7:
  • Pull down the notification shade on your phone then open you Quick Settings menu
  • Tap and hold on the gear icon at the top of the screen for about five seconds. You'll then see a message that says System UI Tuner has been added to Settings.
  • Open the Settings app on your phone and scroll to the bottom. There you'll find System UI Tuner.
Thanks, but how do I turn it off?
Under Nova settings? That's odd. This is how mine shows up:
What phone do you have?
