thisisnascar
At home, I have the option of using WiFi, 4G or 3G. Which of these transports would provide the longest battery life for general usage?
Use Wifi, and turn off your data connection. That way your phone will have internet and voice call capability, without wasting battery constantly searching for and maintaining a 3G or 4G signal. To turn off data just go to your settings, then Data Manager. At the top you have the option called "Data Enabled". Just uncheck that box while you are at home and you will save a significant amount of battery. Just make sure you turn Wifi off when leaving the house, and turn data back on. Hope this helps!
-Albin
I believe there is also a Smart Action profile for turning off mobile data when connected to wifi. That way it should be more or less seemless. When you get to your home/work/wifi-hotspot the wifi connects and the phone turns off the mobile data. When you leave the wifi hotspot the mobile data turns back on.
I have that set up on my phone. Works seamlessly.
Is there a way you could explain to me how to setup that SA rule?
Wifi automatically disables mobile data. Wifi has highest priority. But turn it off if you aren't connected to wifi, because then it wastes battery searching for wifi
Start smart action app.
Click green + sign on upper right
Start from scratch
click + on triggers
click wifi connection
highlight any
save
click + next to actions
tap cellular data
highlight disable
name your rule at top
click add rule at bottom
