I'm trying to find a suitable parental control for my child's phone (Samsung Galaxy A41/Android 11) which I've reset to factory defaults and am busy trying to configure.
After a lot of frustrations I believe I've managed to install Google Family Link, but I'm not sure if it does what I want, if it's overkill and if there are privacy issues I should be concerned about.
I'm not entirely sure how it works either, but as I understand it a child basically gets his/her own user-profile on the phone where any and all phone use goes through an approve/do not approve procedure at Google according to what the parents allow or not. Is this how it works in a nutshell?
I know I can configure how "intrusively involved" myself as a parent can be, but I'm more concerned about Google's intrusiveness -being the middle man so to speak. And do I really need to have all that control?
Basically I want to limit my child's phone use down to being able to make phone calls, send/receive SMS messages and possibly one or two additional apps. I don't want to make the phone too interesting, and the main problem in the past was that it was possible to install any free app from the Google Play store. If I could block the Google Play store with a password, even for free apps I think it would solve most of the problems. So far I haven't found an option for that, or other ways to do it. Suggestions on how to block the Google Play store for my child?
It would also be nice if I could disable, remove or block some apps that the phone (or Android) came with by default. Like I said, I don't want to make the phone too interesting. This probably means restricting the ability to reconfigure the phone as well.
I have heard that it's possible to create a new profile on the phone, and this sounds like a solution, but I'm not sure if it does the above or if it's just for something like a "work" and "home" type of setup, with different types of contacts or whatever, but no restrictions...
I'm confused!![Er... what? o_O o_O](/styles/smilies/google/confused.png)
I'm confused!
