Which remote would you recommend for a MK802 stick?
zilbermm
Hi,
A big consideration is that I need it to support android games.
I know that simple games are not a problem, but what about gyro based games such as temple run?
I was thinking of Mele F10 but will it work well or will the Measy RC11 which has a gyro be a more suitable solution?
Thanks
I'll second that.
I have a 1st gen RF version of the Rii (RT-MWK01) that I'm using with an MK802+ and it is only adequate, not ideal for the purpose.
