hstroph
Android Expert
I'm using a T-Mobile SIM with net10 MVNO, and live in an area with a rather weak signal. It seems that a domestic/small-business signal repeater is in order, and I'd like suggestions on which is the best.
T-Mo, if I understand correctly, is using 850/1900 MHz in the area with plans to upgrade to 1700/2100 MHz AWS service sometime in the future. I'm strongly inclined towards 802770 - Wilson Tri-Band 4G-C Cellular/PCS and AWS 850/1900/1700/2100 MHz but wanted to get your input on other possibilities as well, since it's rather expensive.
I'll probably use an exterior omni-directional antenna for communications with the carrier, as I haven't been able to discover which antenna/tower is being used, and it's not even clear if voice/text and data are on the same antenna location.
