Yeah its slowing ur tablet and also draining its battery.... Two ways are there.:-
1.Download a ram cleaner app like clean master ,360 security etc. And use it.
2. Go to settings>developer options>go to the end of the list> background proccess limit> select a desired option.
Thankyou
RAM cleaners simply lie.But the ram cleaner app worked for my dad's phone that is galaxy s duos .. So it worked for s duos.. But for other phones it maybe not good ....
If you're cleaning cache files, those get rebuilt as you use the apps.Okay those all are shit.... We should use it once in a long term..as it cleans up the thumbnail chache and deletes the useless apks..
I am having lenovo vibe x ... And it has its own factory added file manager that has a clean up app ... In a week i clean 400-500mb space ....
