thank you-I installed Power Toggles and set it up.
eta: even when I turn it on via power toggles it says "device only" in the location modes even if I had it set to regular accurate GPS before. I'm not sure how that mode when on the go using navigation so I'll try it out next time I'm out and about. If I have to change the mode anyway there's no point in using the widget for that although I like having other options that it offers.
hmm mine is not doing that. If it's on it's on device only. If I tap it again it's just off. Then when I tap on, it's on device only again. Is there a setting I'm missing?
That does work but my goal is to toggle between off and on. Is the battery use in the battery saving mode negligible? I'll leave it on for a while and see what my battery monitor says.Try to set GPS to high accuracy manually, and then, tap the widget. Does it switch to battery saving? (go to location settings to verify). Then, tap it again, and see if it switches to high accuracy.
