Help Why does Acrobat DC keep crashing on Kitkat 4.4?
  • Start date Start date
A
Android Question
Guest
I was just getting used to Acrobat DC, then an Adpbe update was pushed out on or about May 28 and since then Acrobat DC consistantly crashes after a few seconds, if it even opens at all. I have an Acer A1-840 with Kitkat 4.4 and nothing changed except for the 'forced' update. I rarely connect to the internet. Just use it to work offline with personal PDF files. The same update works flawlessly on my $49 Nextbook 7.9 running 4.4. I tried a 'factory reset', after boot I ONLY installed 'acrobat', and got the same results. Any thoughts? Thanks
