Why does my Note 5 screen switch in sunlight and fade out?
Crash79
Hi all,
Very frustrating when I am in the sunlight or even overcast outdoors and my Note 5 screen switches from vibrant deep colorful screen to a washed out faded shade. If I cover the sensor areas by the earpiece the screen switches back instantly to a more visible colorful mode.
I have auto brightness turned off completely and I am using "Amoled Cinema" in display settings.
Thanks
Hi all,
Thanks
Kindly provide information such as :
ROM
KERNEL
XPOSED Y/N
and anything else you may believe can help.
Only then will i be able to try and help.
