This has been discussed extensively in the S5570 sub-forum. See if any of the advice here helps you. As basic troubleshooting preliminary, you should try to determine if the problem is unique to your device or not. For example, does your mini work fine on wifi elsewhere (like Starbucks)? If you can, also check to see if other devices have trouble connecting to your home router.
