Ive brought a couple of sd cards to see if it was the sd card and they just refuse to work. Its reads for like 10 minutes then says SD card unexpectedly removed.
Try formatting the card once. If that doesn't work, do a factory reset on the phone.
This has happened with many people, all had different solutions, for some formatting the card was a solution, for some the factory reset and finally there are those who got a new card altogether.
See what works for you.
