psionandy Extreme Android User Aug 3, 2013 #2 Batteries are disposable items... so they hold less charge every month,,, especially if you had it a while. (or it could be a rogue app thats using all your power... check the battery stats)
EarlyMon The PearlyMon VIP Member Aug 3, 2013 #3 Something is probably running a little out of control. Another member had this same problem, so I gave them detailed advice on how to track that down - check it out! http://androidforums.com/galaxy-s2-...ms-cropped-up-during-romming.html#post6034407
