Help Wi-Fi problem
Mutak94
Hello everybody! I have Samsung Galaxy 3 and I am experiencing an annoying problem with its Wi-Fi.
Whenever I try to connect to certain networks it shows "Connecting..." and then after a few seconds "Disconnected". Then it goes through the loop again. It doesn't even start obtaining IP address!
Please help me because one of those certain networks where that happens is at my home. I really hate going to Wi-Fi caffees and buying a drink just to download apps.
if it works in other areas...
then you need to look at your wifi router at home... it might be set to something that your phone does not handle... or some security setting... try changing things around.. and test and test.
worse case ... your router is totally incompatible with your phone. and you will need to get a different one.
It's known glitch by samsung, they have sent updates to fix this issue.
Just did small update via KIES to fix this, WIFI works like a dream now.
Did update on 17/10/2011
My phone is in uk from CPW, unbranded.
