Hello cindia. Are you able to access the web without using your WIFI? Are you certain you are connected to your router? Have you tried connecting to a different WIFI.. say Starbucks or something similar? Those are tests to see if it's your phone or if it's your connection to your router. Once you have narrowed the problem, you will likely get the best help by following this link: Android Lounge - Android Forums
I hope you solve your problem and thanks for using these forums.
