aleshasara
Help! My Wi-Fi won't turn on, it keeps saying that it's being turned on. I am unable to turn it off or on fully. I have restarted my phone countless times but to no avail. Please help!!
Hi,
Having same issue after upgrading to 4.4.2. Powering off the phone does not resolve the issue, I have pulled the battery, as well as per the previous post, pressed the power button while the battery was removed. Same issue. Wifi says it is turning on, but will not turn on. Anyone run into a solution?
Dune.
The only way I found for this issue (cause I have on every reboot)
is to remove the sd card, restart the phone and plug it again.
You can also go to settings - storage - unmount the sd card
and then to perform reboot.
For me it works !
