[WIDGET REQUIRED] data switch
hi im after a switch widget to turn the mobile internet on and off, my HTC hero has one in the default home page but i've switched to launcher pro and the nearest thing i can do is create a shortcut to the settings menu which then means another couple of clicks and i'm lazy!!
preferably a freebie but if needs must then i will pay i guess
many thanks
I use SwitchPro Widget. I think it's $0.99 but well worth it. Along with all the normal "switch" functions you can also have 3g-2g switch, reboot (if rooted), recovery, flashlight via camera flash leds, etc.
