widgetlocker sd card problem
mcavalear
i didn't have the data folder on my sd card so i created it so it was like this:
/data/com.teslacoilsw.widgetlocker/themes
but none of the themes show up in widgetlocker. what am i doing wrong?
Not sure about this but I believe WidgetLocker has to go on the internal memory unless you do a Link2SD.
You'll need to root your phone and use ES File Explorer or Root Explorer to move the files you need to the right place ... can someone confirm?
the path you are using is is correct, and no its not stored in root.
But you have to put the themes you downloaded as it is in ZIP format, dont extract them and then put in the folder.. :)
To add a new widget to my widgetlocker, would I do the following?
Download the .zip
Open Androzip and move the file to /data/com.teslacoilsw.widgetlocker/themes
Open Widgetlocker and it should be there
Is that correct? Or am I missing something, because I can't get mine to work ):
Download the .zip
You might have better luck at getting a answer in one of the WL threads on XDA
[FAQ] WIDGETLOCKER | Documentation and Help thread! | We have answers! - xda-developers
[THEMES] WidgetLocker Theme Collection - xda-developers
