Widgetlocker (SGCap) Easy Wake Method problems:
Dieselbud
Please forgive me if this has been discussed, as I have spent the last 2 days searching here and all over the web for an answer to this problem.
I downloaded widgetlocker (thanks to the recommendations here) and one of the features I loved the most was the 'Easy Wake Method' and being able to wake the phone using the volume key rather than the power key.
There are two reasons for this:
1. I am a lefty, therefore my phone will most always be picked up with this hand.
2. I use a Gel Case that makes the power button really hard to press and it is SUPER annoying, but I really like the case except for that reason.
It worked fine for the first day or so, but now this 'easy wake' function only works intermittently.
This is definitely not a deal breaker for me, but I really would like to just depend on the volume key to wake the phone with my thumb when I pick it up with my left hand. I am otherwise fumbling around trying to press that power key. I actually have a callous on my right thumb from the power button and I do not want to replace my case.
I have tried rebooting, turning on and off the 'use any hardware button to wake', turning on and off the 'allow volume buttons in lock mode' and nothing works.
PS: I am also using the paid version of beautiful widgets and have a weather widget on my lock screen and only 3 other applications on there (text, call button and shopping list, I have tried removing all that stuff too, because I would rather have this function work than any other.
PS I have freakishly tiny hands too and I am a woman so I will complain about things like this LOL Thanks for being patient with me.
Do you have the latest version? I believe it's 2.02.
From the lock screen go to menu>settings>advanced>disable stock lock screen. This allows all hardware buttons to wake the phone.
I definitely have the 2.0.2 version :)
I checked the settings and it tells me it is already disabled due to the use of easy wake mode settings.
Thanks for the suggestions though! I am willing to try anything and everything :)
Well for whatever reason it is working more often than not today, after a few hours of not working at all last night and this morning for a few hours.
This was before I did any of the above and I have since added back my widgets and application shortcuts.
I hope this continues because I really like the feature. But I did not do anything to make it work differently today LOL
I had a similar problem with this new version of WL.
I am also a lefty and make great use of the easy wake feature. While mine has worked very consistently as far as waking but it will usually change the volume up or down (depending on which button i use to wake) only one notch and it makes the short 'ding' noise you get when changing volume. When its on vibrate it doesnt happen nearly as much but sometimes it takes it out of vibrate due to the volume change.
Is anyone else having this problem with version 2.0.2?
PS I have unchecked the setting where it says 'allow volume buttons on lock'
^^ !! Yes! I JUST upgraded tonight, because I switched ROMS and the version I had before was choppy and laggy. I was previously using Myn's Warm and Widgetlocker worked like a dream. All of a sudden I'm using the latest version on Vaelpak and I have been in and out of the settings countless times trying to figure out why using the easy wake mode and the volume buttons to turn the phone on always gives me the audible volume changing beep. Just like you, I don't allow the volume buttons on lock. A glitch in this version maybe?
